Izuzu axle
junkman
roxboro
Anyone know what kind of rear axle is in a 90, 91 Izuzu amigo . I noticed one in a junkyard with disc brakes and was thinking of a possible swap for my cj
Not sure about amigos, but its probably the same as my trooper. I have a 91 trooper that has an isuzu 12 bolt with disk brakes. 6 lug like toyotas, third member, disk brakes and pretty strong from what I can tell. Mine held up great with welded spider gears with 36s and now 38s and a V8.
Thanks ,I believe it is the 12 bolt from your discription
Send a PM to JoeD4x4 on here. Joe Darlington is one of the biggest known names in the isuzu community. He'll be able to help you w/ any quuestions you have about it
the axle is tough as shit. approx. 8.75" ring, 3rd member design, etc. locker options are ARB, stock LSD, or you can sign up for a special production lockright at 4x4wire. Gear ratios are 4.10 (kinda rare) 4.30, 4.56 (most common) 4.77, and 5.38 (tera). the one you're looking at should be about 57.5-58" wide.
contact Joe Darlington here in NC or Matt Brown at Independent4x.com in VA. They are both great vendors.
PM me if you need Joe's contact info. Speaking of which I need to swing by his place to pick up some stuff so if your ever in the goldsboro area let me know and I'll introduce you
