TPoindexter
- Sep 3, 2008
- Davie County
ok here goes, 93 yj 5 speed ford injectors,4.0 throttle body and spacer, mini van fuel regulator, exhaust, firepower coil-8mm wires.
driving to get grocery's and lost all power pulling out of driveway, pulled its self back to house in first around 2500 rmp anything under or over no power and backfiring through intake.
take to shop today check
fuel pressure ok
spark fine
timing fine
valves working as should
compression good
stops running all together, check crank sensor bad ( great found problem)
off to parts store and $66 later jeep runs but is doing same thing as before stopped running so now what?
I think I have ruled out mechanical thinking bad computer? Anyone around WS trade 5 minutes with there computer for a 6 pack?
I'm doing vortec swap but need as DD until wife gets new vehicle. another story but Hemi in her jeep let the #1 piston go so now she has my truck. Will fix hemi but she wants new ride so that's on back burner.
fuel pressure ok
spark fine
timing fine
compression good
