zuksammy
- Dec 2, 2008
- High Point
Hey guys I just bought me a 2000 xj with 155k on the clock. I was driving it around last night and my oil pressure went to zero. So luckily I was at my house. So I popped the hood and the oil pressure switch was broke. So I went this am and got one. Got it in then went for a drive it stays anywhere between 30-45 psi under a load then when I come to a stop 20-25 at idle. So my question is should I go ahead and replace the oil pump and the pickup I know they are bad about goin out? Also while I am in there I can change the rear main while I am in there correct? Cause you don't have to pull the trans do you? Also should I do anything or check anything else since it's my DD???
