- Mar 24, 2005
- Stanley, NC
Who here has done a stroker on their 4.0? List what you did, and how you like it.
Displacement:
Block:
Head:
Crank:
Rods:
Pistons:
Cam:
Injectors:
Intake:
Exhaust:
Cooling:
Rotating Assembly balanced:
Fuel Octane:
1/8-1/4 mile times: 10.6@63, 17.0@76, 5100lbs, 35's
Other/Notes:
I'll start.
Displacement: 4.6L
Block: 2000 TJ 4.0
Head: 2000 TJ 4.0, resurfaced .010 to ensure squareness, otherwise stock
Crank: 87-91 4.2L
Rods: Pre-86 4.2L
Pistons: H802CP, undished, .030" over
Cam: 2000 TJ 4.0
Injectors: 2000 TJ 4.0
Intake: Stock TJ airbox with K&N filter element
Exhaust: Stock TJ
Cooling: Novak Radlock with Taurus fan, tried a "heavy duty" replacement first, but not enough cooling
Rotating Assembly balanced: Yes, and it runs smoother than stock
Fuel Octane: 89
Other/Notes: Had to space stud girdle approximately 3/32" to clear rods. Make sure the rods you recieve are what you ordered. The 4.2 rods I ordered ended up being from a 4.0, and had to be replaced, but this was discovered after the pistons were installed. 2 pistons were busted while removing from the incorrect rods, so I then had to order more and wait.
Overall, I am thrilled with the stroker. It is the only mod that I've done to the jeep that puts a smile on my face everytime I drive it. I've got around 50k miles on it with zero problems. Sorting out the cooling issues was frustrating, but in hindsight, I would put a Taurus fan on a cheap HD radiator and try it. I had a HD radiator with a cheap fan, and it didnt' cut the butter, so I did the Novak aluminum radiator and Taurus fan at the same time. I've been at Uwharrie in the upper 90's with the AC on, and the temp never exceeded 180.
I would highly recommend a stroker to anyone with a 4.0.
Displacement:
Block:
Head:
Crank:
Rods:
Pistons:
Cam:
Injectors:
Intake:
Exhaust:
Cooling:
Fuel Octane:
Other/Notes:
I'll start.
Displacement: 4.6L
Block: 2000 TJ 4.0
Crank: 87-91 4.2L
Rods: Pre-86 4.2L
Cam: 2000 TJ 4.0
Exhaust: Stock TJ
Fuel Octane: 89
