.:Scooter:.
- Jul 27, 2007
- Hickory, NC
1979 cj5 aniversary eddition
D30 - AMC20 with 3.54's right now, posi in the rear.
i dont want D60's/70's or rockwells. mainly because the trails and moutains i ride are in dense forrests. need the shorter wheelbases and a little more stability plus ill want to run 35x15.50 TSL-SX's.
common axle swaps ive seen are widetrack D44's out of later CJ's.
D44 - D44 waggy swaps.
and D44 - Ford 9" or Ford 8.8"?
Scout axles too.. but the nuck's have to be rotated back about 6 degrees right?
i am aware of having to outboard the front springs and such.
fronts gotta be pass drop. could someone also refresh my memory on the high-pinion? ill be wanting to go SOA and put the tie-rod over the springs. possible or what am i missing?
also, are F250 shock towers what most Cj5 guys are using for the shocks or custom making or something else? i cant find anything to be 100% sure.
theres alot of questions in there. any links to info would be appreciated and any local guys around Hickory NC that know a good bit on axle rebuilds. thanks for any help on clarifying what i know and correcting me.
-matt
-matt
