I had a guy at my work do a state inspection on my 1996 Jeep Grand Cherokee with a 4.0 yesterday. He suggested a oil change because the last person that changed it put the oil filter on so tight that it was causing the seal to leak. Changed the oil and filter and everything was fine. He sprayed brake cleaner on the passenger side of the block because there was grease/oil build up from a previous valve cover gasket leak. He waited about 5 minutes and cranked it and it caught fire right where the coil is but it was just the wire loom coming from the coil. We checked all the wires inside the loom and they appear to be fine. He put the fire out in enough time before it got bad.
I didn't notice it until I was driving the Jeep home though that the Jeep was missing. At idle it will be idling smooth and then just out of nowhere jerk/stumble. You can't feel a miss while driving it down the road. It's just at idle. Also, when sitting at idle and revving to slowly build up RPM's it will start hesitating/cutting out/missing at 1500-2000rpm's if you just let the RPM's gradually build. If you stab the throttle it's fine though. The Jeep didn't miss a lick before I brought it into the shop. Is the Jeep going to need a wiring harness or??
maybe thats another jeep thing
