matt1u2
- Apr 23, 2009
- florence,sc
I have a 77 Jeep CJ5 with a 304. I have removed the 3 speed and am going to install a T176. When I removed the 3 speed and could get to the clutch the pressure plate had lots of fingers where the release bearing rides.
My friend gave me a new clutch, pressure plate and the clutch release bearing kit that a purchased but didn't use. He had similar problems I had with the clutch not fitting. In the end he went to automatic instead so he didn't use the kit.
The problem is the clutch will not slide on the T176 shaft because the hole is too small. Same tooth count just too small.
My question is. can I use the new pressure plate and release bearing and just buy a new clutch? The new pressure plate only has 3 fingers where the release bearing rides.
Are they interchagable. I have read the T15 had a smaller diameter shaft so I am guessing that is what this kit was for but can I use the pressure plate and purchase a new clutch?
Thanks
Thanks
