orange150
- Mar 20, 2005
- Fairfax City, VA
The "ice" has scared most people away from work today, so I'm just sitting here, fueled on coffee and thinking about everything other than work.
My DD Jeep is currently on the stock axles, with stock gears, with 33s. Which really sucks.
I've gone over this before, but my Jeep is my DD, like I said, so it sees 90%-95% street time, with the other being farm work. The farm work means it needs to be able to pull trailers and handle at least some load, which I am hesitant to do now with it's current axle set up. I do plan to start going to Uwharrie once the axles are addressed, and hopefully branch out from there one day.
I have a rear D44 out of an '86 that I will be regearing to 4.10 as soon as I've saved up to get the job done.
So here's where the dilemma comes. I can either regear my D30 front, or install the Scout D44 front w/ 4.10s that I have sitting on jack stands right now.
Regear the D30
Install the Scout 44
I would rather install the 44 because of all the perks it provides; it's stronger, wider, requires the springs to be outboarded which will give me better suspension performance. But, I am by no means skilled enough to do the job myself, so I have to shop the whole thing out. And it being my DD I am slightly concerned about down time, but only slightly.
I can't see the 44 install costing too much more than regearing the 30. I feel like a good fabricator could outboard the springs fairly easily, then it's just swapping the outers and getting steering links... Right? If I need a new drive shaft I could at least drive it while one is being made.
Or, I just run down the road to ECGS and have them regear the D30...
That's my dilemma. I've been mulling over it for a long time, but I need to do something as soon as I can afford it because driving on the stock gears is getting old. Fast.
Regear the D30
- The "easier" of the two options as all it requires is the regear (which would really grow into a complete rebuild of the D30; new/upgraded u-joints, ball joints, etc), but do I really want to spend the money on that axle, when I have the stronger, wider, Scout 44 already?
- To keep costs down I would swap the D30 outers onto that axle, so brakes, steering (aside from width), etc. would all swap over. <- Would be long term temporary.
- Axle is already geared to 4.10
- I would need to outboard the front springs, which is an upgrade for the Jeep, but an additional cost.
- The Scout 44 camber would need to be adjusted, so a cut and turn of the knuckles.
- New steering links.
- Would need to run 2" spacers on the Jeep 44 rear to match width. Not a big deal IMO. <- Probably end up being long term temp as well
to 4.56 in his '84 CJ-7 w/ TBI'd 258/T-4/D300 & 33"s and is screaming (3K+ rpm) at 55 mph. It does very well offroad, but the on road has really suffered... Now he wishes he'd gone a little more conservative (3.54-3.73) to keep the R's down on road and 4:1'd the D300 for offroad
