ok 300$, i am listening.....
The "what we did" links are both posted above, so I'll give you the rundown on the cost.
*MINE* was a little over $300 (replaced entire fuel plumbing & replaced several of the sensor plugs) and Taters was under $300...
$100 -
Complete TBI system from a junkyard... TB, air cleaner, fuel lines, wiring harness, ECM, O2, dizzy(for the EST), knock sensor, coil, MAP sensor, ESC, relays... *everything remotely acquainted with the TBI system*
$30 - 3/4"x12"x6" AL stock for TB-manifoldadapters from McMaster-Carr (made both adapters from this pc)
$25 - TB "rebuild" kit (includes new base gaskets)
$35 - fleabay variety E-2000 "Ford" fuel pump
$25 - assorted fuel plumbing parts (FI hose, FI clamps, new pre-pump filter, nylon-steel line couplers, etc)
$25 - assorted wires, solder, heat-shrink, split loom
$25 - assorted general misc (makes the math closer
$25 - ZIF socket for ECM from Moates (5 second chip swaps) & entire sleeve of 27SF512 chips (will hold multiple & selectable tunes if you'd like) shipped from mainland China (qty of 18... have a dozen left)
$3 - HELP! variety "Spark Plug Anti-Foulers" (14mm sockets to weld in exhaust for O2 sensor)
$293 total...
The cost of the AL plate & anti-foulers was shared, as there was enough to do both.
The ZIF socket/upgraded chips can be nixed if you'd like (IMO, the OE chips/carriers are of the Devil himself & I *refuse* to dance!)
Does not include the Moates BurnII I bought just to be able to quickly erase/burn the upgraded chips ($100) or the beer consumed during the swaps!
We now share an ammo can of TBI "spares"... fuelpump, ECM, spare chips (w/ our individual tunes), netres/"limp home" chips (specific for 6 or 8 cylinder), fittings, connectors, EST & ESC, coil, relays, FI hose/clamps, etc that can be thrown in either rig...
