Jeep Interiors at MidCarolina Line-X - TJ/YJ/CJ/LJ/JK - Pricing and options here.
Will Carter
Burlington
We do quite a few interiors a month here.
TJ/YJ/CJ/LJ's - Pricing starts at $400 if you bring it to us with just a driver's seat and driver's seat belt. This means you have already removed the following:
-Top
-Carpet
-Seat belts (you can leave the top bolt that's in the cage on the seatbelts, just leave them hanging)
-Seats and associated brackets
-Center console (you can leave the ebrake and shifter brackets)
-Tcase shifter bracket bolts if you don't want them sprayed (beside your right leg on the side of the trans hump, silver bolts)
-Jack, tire iron and hold down straps
-Plastic wire cover on drivers side under door
-Pop all wires out of the holding brackets or out of their floor studs (don't have to unplug anything, we'll do that and plug it all back up)
-Rear door latch cover (you can leave the latch attached to the fender well so the door doesn't swing around)
-Rear door brake light wire cover
-If you want the cage to be removable in the future without cutting the Line-X go ahead and take it out
-Smooth out any body putty clumps in the floor if you want. Line-X will cover some of the smaller stuff but you will still be able to see any imperfections in the surface if they're larger than a penny or so.
-If it's in the floor and you don't want it sprayed - Take it out.
OR, if you'd like to bring us your jeep and have us take it all out and put it all back in after we spray we can do it for $600.
JK's - 2 door starting at $500, 4 doors starting at $600 if you bring it to us with nothing but a driver's seat and driver's seat belt.
-All of the TJ stuff applies to the JK except a JK has more interior plastic that has to be removed. There's panels on the driver and passenger side that cover wires that need to come off
OR, we can take care of everything for you for $200 additional on either 2 door or 4 door.
Most can be completed the same day.
If you have any questions or are ready to schedule an appointment give us a call at 336-449-0550 or hit us up at facebook.com/MidCarolinaLineX.
Here's a few pictures of a 4 door JK we did last week.
