Jeep jk door removal
Floor jack under the door with a 2x4 and a towel to prevent scratches. Easy pressure up to break it loose.
And some help.
I know on CJ/YJs, after you take the nut off each hinge, the door should lift straight up and out. Sometimes they get a little bound up and you have to wiggle it while applying upward force, walking it up/out bit by bit. No clue on a JK though
try the 2x4 with a jack or, swing the door back and forth with upward force to walk it out.
Window rolled down , stand on outside of door with it open , upward pressure and move door back and forth as you apply upward pressure
They are heavier than you think..
