Jeep loss of power
camsloop
Concord, Nc
99 jeep grand cherokee, 107k , 4.7l awd. Here recently since its been getting cold, the jeep has a loss of power almost as if im towing a trailer or the engine has a load on it from 0-45 mostly.. During temp. over 40-50 deg. it seems to run normal. The airfilter/ throttle body is both clean. Ive ran 93 gas an 4oz of lucas fuel inj. cleaner an it seemed to barely help. Gas mileage has went down just a little bit but not tremendously. Possibly fuel injectors, engine temp or throttle body sensor, clogged cat, tune up? The jeep hasnt thrown any codes. Any advice? thanks, cam
I'd bet clogged cat. Easiest would be pull the o2 sensor and see if it drives any better. You can also plug a vac/pressure gauge in before the cat and check backpressure while its running.
