Grape Ape
- Mar 29, 2005
- High Point, NC
Ok, so I finally got around to try out the 4 wheel drive in the TJ last night. Found out that 4-Low will not engage, and leaves me just sitting there. It seems to work in 4-Hi, but not 4-Low. I have tried placing the lever smoothly, and somewhat forcably into the 4-Low position, as far as it will go, but it will not engage, and the Jeep won't move. There is a whirring noise when I put it in gear (manual) and try to move. As if the gears are almost engaged, but not quite, and not allowing any drive. I have not had a chance to look underneath or check anything yet, but does anyone know what it might be?
Does the handle and/or shift rods need to be adjusted, if they can be?
I may have to get it off the ground to see if the 4WD is engaging at all.
Help!!!
Help!!!
