Barnes 4wd
- Aug 6, 2007
- Etowah NC
his is our Jeep TJ Ford 8.8 truss axle swap kit, this is a complete bracket kit to swap a Ford 8.8 into your Jeep TJ or LJ with the added benefit of a truss. The 8.8 is a huge upgrade in the jeep, it has a matching lug pattern, a much larger ring and pinion, larger axle shafts, and a overall stronger housing than the stock axle. With this kit you will be able to make the 8.8 even stronger with the addition of a truss, the upper control arm mounts are also keyed to the truss making it much easier to locate where the brackets need to go. With this kit all of the brackets are designed to go in the same location as factory, so none of the brackets on the frame have to be changed. We have used our Ultra 100 steel in all of the key high stress areas making this the strongest bracket kit on the market!
Jeep TJ 8.8 Swap Kit With Truss
Barnes 4wd is proud to offer our Jeep TJ rear axle bracket kit, this is for the do it yourself folks that want to swap the rear axle in their Jeep TJ or LJ. This is a complete kit that comes with all the brackets needed to swap a different rear axle into your Jeep, all brackets are cut to fit a 3 1/4" axle tube (Ford 8.8) but will fit other size tubes with minor modification. We have used our exceptionally strong ultra 100 steel in all of the high stress areas of this kit, so you can rest assured that this is the strongest kit on the market. This kit is designed to maintain all factory mounting locations and is suitable to use with most aftermarket lift kits.
Jeep TJ Rear Axle Brackets
