JEEP TJ, LJ, MJ, XJ, AND ZJ FRONT AXLE TRACK BAR BRACKET
Barnes 4wd
Etowah NC
Introducing our Jeep TJ, LJ, MJ, XJ, and ZJ, front axle track bar bracket. This is a direct replacement for your factory front axle track bar bracket. This bracket is a perfect solution if the track bar bracket bolt hole in your existing bracket is "wallowed out". This bracket is manufactured from 3/16 steel making it much thicker and stronger than the stock bracket. You will need to cut off your existing bracket, and weld this bracket in it's place. Because this bracket is thicker than the factory bracket, the factory steering stabilizer bracket will need to be trimmed slightly where it will come into contact with this bracket. You will receive one bracket in bare steel, cutting and welding is required.
tj-front-axle-track-bar-bracket-jpg.256874
