336wheeler
- Sep 9, 2006
- Boone
So I finally figured out why my freaking Jeep isn't wanting to fire. I pulled the tranny out to make sure I had put the correct flexplate in it - I had. I put my crank position sensor into the bellhousing to make sure the depth to the flexplate was good. The problem - the torque converter doesn't sit far enough back in the transmission casing for the CPS to read the discontinous "squares" in the ring around the flexplate, so in turn it's not getting any blipping action going on to do anything. Can anybody think of a reason why my torque converter won't go far enough back for the flexplate to sit so that the CPS will read the squares? It's 27 spline, non lock-up. It may have rebuilt, I'm not sure. It's in a TF999... I have a new TC on the way, but if nothing is wrong with the one I have then the new TC will sit in the same position. Any thoughts?
