cjwayne
- Nov 18, 2008
- raleigh n.c.
st. 6 out of a xj put in a yj ran fine then just died on the trail will turn over but will not start we have tried everything what could it be any help
yes it isIf it is getting fuel, I would bet it is the CPS
tried all that it will turn over like it wants to start you can smell fuel but it will not start put in a new computer still will not startfuel, spark, computer or ignition control module, starter solenoid, battery, good grounds etc...
And make sure to check the rail pressure. Just because you can smell fuel doesn't always mean it's getting enough.
no it will not but will run off of carb cleanerWill it start if you push on the gas some? Maybe idle air control valve.
Sounds like the fuel system is clogged up or your fuel pump is bad.
