Jeep Wrangler electric fan question
1983Bronco
On your mom in Winston Salem NC
Ok I remember reading about some electric fan that everybody was putting on their wrangler, maybe off of a taurus or something. My Wrangler has got an electric on it now, but its weak. Just looking for something I can get out of a yard cheap. thanks
It is a Taurus fan, I believe mine is off a 96'
There are one and two speed models, But Mine is a one speed and pulls like a beast. It almost bolts directly to the radiator in the existing fan shroud holes. I had to fab up one mount the others lined up.
Here ya go, Read away.
http://www.pirate4x4.com/tech/taurus/
thanks scored a 2 speed from Pull a part for $15!!
Very nice find
Yeah only negative is the shroud is too wide for stock radiator, I bet the single speed like you got fits perfect, it looked narrower at the junkyard
i have the compleate flex-a-lite fan kit on my 4.0 wrangler. i love it except for that gay looking temp. probe you stick in the radiator and then curl the rest of the probe line up in a bunch. The Taurus fan is the way to go. How do you have your fan wired?
I have the gay temp sensor also, But I wired it to a two position toggle and a 30 amp relay, Up is running through the temp sensor, down is direct power to the relay, middle is off. This way I can bypass the temp if need and kill the fan power if needed. I also have an led wired to the fan so that when its running the light is on.
Here is the my diagram of how its wired,
