nc_52 New Member Joined Apr 9, 2014 Location Wilkes Apr 14, 2014 #1 I have a 91 yj and notice today that when I engage the clutch at slower speeds there is this consistent clunk coming from under the jeep. It just started today. Any help is appreciated thanks
nc_52 New Member Joined Apr 9, 2014 Location Wilkes Apr 14, 2014 #2 Revised: it does it anytime under 10 mph regardless of the clutch being engaged
grapehead Well-Known Member Joined Mar 21, 2005 Location Raleigh Apr 14, 2014 #3 check the ujoints in the front driveshaft, i remember my brother's xj making a noise when his were worn out.
GotWood Sayer of Fact Joined Jan 12, 2007 Location Maiden, NC Apr 14, 2014 #4 Only when moving? Will it make noise just sitting with the clutch in/out?
nc_52 New Member Joined Apr 9, 2014 Location Wilkes Apr 14, 2014 #5 No only moving when come to a stop the noise stops regardless
upnover Grumpy, decrepit Old Man Moderator Joined Mar 20, 2005 Location Morganton NC Apr 14, 2014 #6 I'd say either U-Joint , broke spring, loose spring pack, or maybe broke spring center bolt
buckshot500 Well-Known Member Joined Mar 23, 2008 Location Clover S.C. Apr 14, 2014 #7 You might want to check the transmission mount and motor mounts while you are under there.
Louie4 Injanir Joined May 5, 2014 Location Raleigh May 5, 2014 #8 Don't forget the torque arm stud. The nut on the bottom may have come off and it's banging the cross member under acceleration and engine torque.
