ltrpilot9
- Oct 15, 2012
I have a 1994 Jeep Wrangler YJ with a 4.0 and a 5 speed. The jeep is parked outside and it was wet and cold this morning before work. It ran fine this morning, but the engine died today on the way home from work like I shut off the key. No sputter, just instant stop. It will crank, but it wont fire. I checked the fuses and the 30amp fuse for the ECU was blown. I pulled the one out of the headlights and put it in to see if I could limp it home, and it instantly blew when I tried to crank it. I did some more checking while I waited for my wife to pick me up and it looks like theO2 sensor, the ECU, the crank position sensor, the auto shutdown relay and the fuel pump are on that circuit. I picked up 4 new fuses and went back to troublshoot. I disconnected the O2 sensor and auto shutdown relay for the first test to see if either of those was the culprit. The first try with both unplugged the Fuse stayed good on crank. I plugged the O2 sensor back in and tried it again and the fuse stayed good. I plugged the auto kill relay back in sure that this would be my problem, but the fuse stayed good. So now it is not longer blowing the 30amp fuse, but still wont start. I am thinking fuel pump, when I turn on the key I cant hear it run. I don't know if I should be able to or not, I have never really paid attention or listened for it. I really don't understand why it would blow the fuse one minute, and not a half hour later. I need to preface your comments with the knowledge that the electrical system is not my strong suit. Assume I don't know anything and proceed from there. ANY advice is welcome.
