JK ARB Twin Compressor Mounting Bracket
Barnes 4wd
Etowah NC
The Barnes 4wd ARB dual compressor mount is a great solution for installing the ARB twin compressor (ARB part # CKMTA12) in your Jeep Wrangler JK, it is manufactured from 10ga steel and is the strongest design on the market. There isn't much room under the hood of the JK and mounting accessories can be a daunting task, but we here at Barnes 4wd have just made life a little easier, this bracket can be installed in a matter of minutes and no drilling is required! This bracket is designed to work with all JK's 07-up and will also work with the popular SPOD upgrade. The bracket uses three of the factory mounting points, it is mounted to all metal components, and is gusseted to make it extremely rigid when installed. The compressor can be installed with the wiring facing the firewall or with it facing the front of the Jeep. The bracket will come bare and will need to be painted or powder coated before installation.
