Opinions or experiences with Kaufman trailers? I'm going to be getting a 7 ton, 20' tag-along, and ran across their website. I've looked at a couple. One guy out 64E has some including one that is slightly used for a few hundred less than new.
NC_Mog said:Like what? Too light gage? Poor routing? Poor terminations?
NC_Mog said:Opinions or experiences with Kaufman trailers? I'm going to be getting a 7 ton, 20' tag-along, and ran across their website. I've looked at a couple. One guy out 64E has some including one that is slightly used for a few hundred less than new.
FishHunt said:Either way I'd go with the diamond plate. No one ever looked back and said "Damn I wished I had got the wood floor on my trailer". Well no one I know anyway
<><Fish
I looked at a lot of trailers arr over NC,Tenn, and Va.NC_Mog said:Opinions or experiences with Kaufman trailers? I'm going to be getting a 7 ton, 20' tag-along, and ran across their website. I've looked at a couple. One guy out 64E has some including one that is slightly used for a few hundred less than new.
Thanks I will look it over.Rob said:Jon, check your connector, I found two wires that had come undone, I think they shorted out and are causing a problem with the truck. But this is after the day I picked it up, we hooked it up, and the trailer kept blowing my fuses, took them an hour to find a bad connection.
FishHunt said:Off Topic...
I thought that after 26,000# you needed CDL Class A or B, but were fine driving a single rear axle (driving axle) with 26,000# or less. Am I misinformed?
<><Fish
saf-t scissors said:Trailer has to be less than 10k, regardless of GCVW.
I was thinking it was more in the range of 6500 to 7000. You will need a bigger trailer then a 10k.NC_Mog said:It's not a CDL but a regular license Class A versus the normal Class C. I still need to contact DMV and see what it will take to upgrade the license.
Yes I need a hefty trailer. A 10k won't cut it. Based on Kermit, trail ready will tip the scales at approximately 8200 lb. Assuming a 14k trailer, we'll add another 2800 lb for a grand total of 11k. Personally, I'd rather step up to a 14k trailer and have the extra safety margin versus going with a 12k. The cost differential is not that much.
