Blaze
The Jeeper Reaper
- Aug 9, 2005
- Wake Forest, NC
OK, so I'm at a crossroads here. I need to make a decision here. My current truck has 260k miles on it, it is a 2000 Silverado 4x4 2500 with the 6.0L. The transmission is acting up, and it has some odd electrical gremlins. It is my daily driver and it works perfect for anywhere up to 30 or so miles before the transmission gets hot. Towing it gets hot really quickly. Can not figure out why, trans is relatively new and has had a ton of parts replaced, etc. Wasn't as bad when I got it a year ago, but it has gotten much worse. On top of that it has started leaking transmission fluid from the seal between the trans and tcase. Might actually be pump rub, but might just be a gasket. And it leaks oil from the oil cooler fittings even though I have replaced them and the orings.
My side business depends on me being able to tow my 16' trailer with a car on it, at least once a week when we get moved in to the new house. I need to make a decision on this thing. I am planning on keeping the S-10 Blazer I was trying to sell and use it as my DD. No one seems to want it for the price I was asking, so might as well keep it for a good DD. This means my truck will probably be used about twice a week at most.
So, trying to figure this out. Do I throw some money at the truck trying to fix the transmission and other issues, or do I punt. I figure I can get maybe $3500 as it is, probably more like $3000. I'm thinking of taking that and looking for an older dually. Something like either a squarebody crew cab dually Chevy or an extended cab/crew cab dually Chevy with the 454. Seems like I can find a lot of them with around 150k miles for around $3000-$3500. I know my old 99 2500 454 Suburban would tow like a beast, so I imagine these would be the same. The crew cab would be nice to haul the fam around in, but I guess an extended cab one would be ok if need be.
What do you guys think? Try and fix the current truck or go ahead and look for an older beast?
I'm leaning towards the dually. Because BBC and 19.5" wheels.....
