Kernersville light welding on exhaust work needed?
SHINTON
Triad area of NC
Was not sure if there was another good place to put this but I am needing a couple items done and would rather pay a 4x4er instead of a local garage?
First thing I need is a bit of welding on my exhaust! 1995 Jeep Wrangler YJ, got looking at it last night and the previous owner had wrapped "tin" (thin sheet metal) of some sort around the pipe just in front of Catalytic converter, and put hose clamps on to hold it all. Naturally this failed on the 20 mile drive from Summerfield to Kernersville and my exhaust now ends just in front of the cat.
It looks like everything else is pretty legit, I was thinking it would all be rotted out but just this simple cut that needs to be welded together, or spliced / clamped, don't really know? I could drive it (LOUD and no backpressure) down to a shop but if you have a welder you can bring with you, and some materials, give me a shout? Heck you probably could just splice in a new section of pipe, clamp it all down good, no welder needed?
This is the section OVER the skidplate, so a PITA to get to, thus the reason I am punting!
Other stuff... if you happened to want to do an oil change and new filter I would be good with that vs local shop. My filter is likely from 2007-2008 timeframe and I think the seal was DRY and thus oil was coming out around it on that notorious drive home. Good amount of wet / hot oil and that is the only real source on that side of the engine. I figure a new filter / oil change would be a good first step here. I could do that myself but I never change my own oil, do not have the wrenches, pans, want to dispose of old oil and such. Worst case I will pay the garage to do this but if you are willing and able?
I am near the Walmart in Kernersville, we can talk timing and such if you want to reply here or send PM.
Sam
Thanks Tom, appreciate it!!! I have a stick welder but my skillz are lacking! Stick might work good though since you can weld it from a distance!
I live off Kernersville rd right past linville rd. I'd be glad to give you a hand. Can't be more than a mile or so from you to my house.
Yeah you are a mile down the road at most! Zap me a PM at some point, I have figured out I can slip a 2.5" connector on the exhaust to connect the two parts and bought clamps to tighten them all down. My CURRENT issue is how you get the durn rubber isolater back off the brackets? If I could get the exhaust to move back about 2-3" I could use this clamp/connector and be done with this part!! Not as good as welding but for $12 of parts it would be an easy fix.
Any suggestions from the peanut gallery? I pulled like heck with vice grips after spraying down with WD40 but nada. Got thinking later on though that I could use a racheting tie down strap and that would keep the pressure on it, and use it to PULL off the isolater. There are two right at muffler, I think if they come off the exhaust will move back enough I can get the pipe into this connector and then clamp it all down good!? (Hoping it will not still leak there!? Not used clamps before...)
