If you dont know how to setup air shocks, you probably shouldnt. They are not supplied with instructions b/c there is nothing for basis. Each application, ie: travel, weight, rebound, dampen, is different for each and every vehicle they are mounted on and individuals ride likings. A quick rundown: Most air shocks are shipped with a 60/40 dampen/rebound. The compressed nitrogen will only net you ride height, not ride quality. You can add oil through the shrader valve to adjust compression, ie: soft/hard ride. To adjust the rebound, the shock needs taken apart and the washers swapped. But, a little trick of the trade is different weight shock oil with give different rebound results, ie: a 20w shock oil has a slower rebound as where a 5w oil will rebound quickly.
Most DIY apps are ready out of the box, just add nitrogen and go. If you want a stiffer ride, deflate and add a few cc's of oil.
