knocking
football76_us
Pembroke nc
I have a 2001 dodge ram 4x4 that has a knocking in both sides of the front axle area when the truck is moving, not sure what it is. Does anyone have any suggestion of what it might be.
Probably unit bearings or U-joints. Jack the front wheels off the ground and see if the wheel bearings are tight by wiggling the wheel around. If your running a 10" wide wheel or a really negative offset 8" wheel your gonna probably go through unit bearings pretty fast. Thats a pretty common problem with the ram 1/2 ton dana 44.
