Chuckman
- Oct 9, 2005
- Huntersville
Axle Off-Set Plate for 2-1/2
^ above post; Im putting stock YJ springs under a CJ2A. this means that the front of the springs are going to be 4" or so out past the stock location. not the best for approach angle and keeping the 'look' of a flatty. same for the rear. choosing the YJ's for flex and ride / maintaining similar load design
so MORE has this design to move the axles fore/aft by 3/4" and 1" depending on which hole you choose. this is the same principle as some of the older flatty custom spring packs intended for longer travel/softer ride so I know the concept works (offset pin, not a 'moved' pin). my question is- would it be a horrible idea to make two sets of these (front and rear) as much as 3" offset? It would solve all sorts of shackle fitment problems. Id rather lose 1/4" of lift and not redrill new holes. honestly I cant think of too much to go wrong as long as things are clamped down tight. BUT I may be missing something.
Ive run SOA and had hella issues with spring wrap, will these springs behave better going SUA? will this mod make spring wrap worse or less?
will 'little' 31" tires and SUA induce much wrap? lotta wranglers sold that way...
