powerstrokin04
- Oct 2, 2008
- Ellenboro NC
I'm using used leaf spring u bolts for my rear axle swap. The problem is that they are wider than the spring plate holes. I need to compress the bolts so that they will fit. First off I don't have channel locks big enough to compress them. I already tried to compress them in a vice but they sprung back to original size. A 4" ratchet strap didn't work nor did a hammer. And no gas for torch. The axle, springs, plates, and u bolts were used together before. Any thoughts before I buy new ones? Thanks
