Leaking steering box
BigClay
Knower of useless ZJ things
Winston-Salem
My steering box is leaking pretty good, how hard is it to rebuild one? Anyone rebuild steering boxes in the triad?
Where is it leaking from? Is it on your ZJ? I think I've got a writeup on rebuilding those boxes somewhere, ill do a little digging.
It is actually on a TJ I just got.
I just did some digging and looks like a durango box could be a small upgrade for the stocker.
As dkrajcovic said... Just replace if you can find one reasonable. I have overhauled many a Saginaw box, and it is tedious at best. And the kits alone are near the cost of a good junkyard box!
Saginaw boxes generally aren't troublesome, so having one that leaks and has problems is not common.
clay there is a seal on the sector shaft you can change out pretty easily without completely tearing the box down but i'd go with an upgrade or a replacement box because there's a reason its leaking like a worn bearing or shaft and you'll come out ahead to do an upgrade.. plus you'll have the leaky box to try and fix for a spare...
Autozone/Advance/etc lifetime replacement.
The Astro steering box is only useful if you want to move the axle forward more than 3".
