UTfball68
- Jul 18, 2008
- Granite Quarry
LEB Steering Linkage (Heim Joint):
Featuring 3/4x3/4 kevlar lined chromoly heim joints and 1.5x.250 DOM tubing, these are heavy duty steering links for your off road or race truck. Drag links and tie rod sold as a set. Trac bars will come with 3/4x3/4 heim joints as well.
Trac bars are provided with 5/8x3/4 misalignment spacers for frame side.
Knuckles will need to be drilled to 3/4".
All grade 8 hardware supplied, including castle nuts and safety pins to ensure your steering links stay tight.
Tie rod and drag link set are 349.99. Trac bar is 149.99. Full set available for 474.99 (drag link, tie rod, trac bar).
LEB Steering Linkage (One Ton TRE):
Featuring one ton tie rod ends and 1.5x.250 DOM tubing, these are heavy duty steering links for your street/trail truck. Drag links and tie rod sold as a set. Trac bars will come with 3/4x3/4 heim joints.
Knuckles and pitman arm will need to be reamed to 7* taper or drilled to 7/8" if you select optional tapered inserts.
