tusk762
Member
- Jun 6, 2007
- wilmington
but damn its still a liberty
Ok cheif, I will just go back to web-fabbing then. I have built enough link suspensions to know the shock hitting the frame isnt right. Glad its getting fixed and the rest of the fab looks good. Why the dana 30? A 44 seems more to suite.
Since you're fixing it, it appears all those web fabbers that got under your skin were right.Just so all the web fabbers can sleep at night i took the shock pic down, its being fixed as we speak. Just got to move the upper shock mount outwards about an 1". What would i do without all the web fabbers/wheelers input?
That's like me saying my built 44 is as strong as a 60. Sounds good, but just ignoring the truth. You gotta consider the size differences of the ball joints, ring and pinion, bearings, ect... I do like your liberty, though. It's the first time I've ever seen one that looks that good....and a hp30 built is as strong as a 44...
No body seems to relize that when doing a swap like this that everything is a compromise, liberty's weren't meant to have a solid front axle and steering box. So of course everything can't be perfect its all about compromises to get everything work as good as it possibly can. We're still working out the bugs but it should be good to go in a day or so.
My goal with this was to fit the 33's without making the rig stupid high and top heavy looking( i hate tall rigs), It handles really well and doesn't seem top heavy at all
Now i'm swapping the front tcase output with a TJ one so we can use a TJ front driveshaft, fixing the shock mounts.
Here's some pics next to the stock liberty
Good, I wasn't going to be the first to say...I would suggest moving that heim in the vertical position instead of the horizontal position. Unless you have some limit straps or bump stops I can eventually see the track-bar bending or just ripping right off the frame....
Sam, could you come up and give me your expert review of my project?I also wasnt going to point out the trac bar but it def needs some work. What was the benifit of mounting it that way anywho? Like i said before...good execution...just need to work on the layout and idea of it working offroad.
if would flex a lot better after the coil overs are moved out
