silver
Member
- Oct 4, 2007
- winston-salem, nc
alright, i am getting ready to RE-own a 2000 f250 superduty i once owned. Its a shortbed, ext cab. 8in lift with 38's. I had replaced the tires when I had it and replaced all the shocks and the steering stabilizer shock. it still drove like crap. LOT of play in the steering wheel was the MAIN issue and it wandered around on the road. I may could have dealt with the wandering BUT the steering was so sloppy, you had to turn the steering wheel half-turn to correct it.
Anyway, we also rebuilt the front end with ball-joints etc and alignment.
while the other guy has owned it, first off, he didnt mind the way it drove. I hated it. He got used to it. Anyway. One of the front hubs locked up and he replaced both. He said the driver side appeared to be engaged in 4wd all the time and that caused the wandering, it finally locked up. He says it drives a LOT better now.
Secondly, the steering gearbox is shot. He is replacing it tomorrow with a brand new one and says it will take care of the slop in the steering. Is this true?
anyway, what can i try to cure the wandering if it is still bad? The front stabilizer is a single shock setup. Should I change to dual. Any advantage into changing to a multi-shock setup on the tires instead of right now, it has single shocks all around.
IDEAS?
IDEAS?
