NOTE: The following what I posted on Pirate4x4.com and got a bunch of TJjockytard responses. I should have known better and just asked here first.
Do the lifters have to be empty of oil when measuring preload (not pumped up)?
Some details on why I ask.
258 block and crank. Stock Cam. New lifters. 258 push rods. 4.0 head and rockers.
This is on a fresh rebuild. I haven't been able to get the motor to run. It'll fire, but something isn't right. It seems to have compression when turning over by hand, but sounds odd when cranking. A compression tester yielded basically no compression. I don't entirely trust the tester, but it should read something.
I double checked the timing chain. There are two circles on the crank, but one is clearly a stamped mark, and the other appears to be a casting dimple. I went with the stamped circle. The cam sprocket doesn't have a circle, but has a little arrow looking thing. Using the line between the shafts, both marks on that on the inside, and then turning and counting pins, yields 15. Looks correct.
Next thing is lifter preload.
This is my procedure. Turn engine till there's no tension on the rockers. Scribe line on pushrod. Loosen rocker arm bolts till pushrod stops rising. Scribe another mark. Measure distance between lines.
The thing this, when I tighten the rocker arms down, they appear to compress the valves some. The Preload measures at .038" This is with the lifters full of oil.
Any ideas?
Any ideas?
