With a 3 inch you will likely need a new front driveshaft, It might last for a while but the boot will eventually tear. If you are doing a 3 inch make sure whatever lift you are doing includes adjustable control arms( to correct your front caster). It will likely drive bad and will wander around a lot.
This is just my opinioun, dont cheap out on your lift, especially at that height, If you do it will be regretted. Crappy parts brings crappy results.If you are going that tall then I assume you are going to atleast 35,s, if you plan on wheeling often and/or hard, I would suggest adressing your ball joints and consider gusseting the inner c,s. This is cheap insurance down the road.
For the best info on building a Jk, give Carolina Metal Masters a call, they know Jk,s inside and out, can get you the qaulity parts you need and can build the Jeep for you if needed.
