limited slip question
X2^^^ Eventually your clutches will burn up and you will end up with open rear end and after that there is a chance the clutch pad dust that is in your oil with ruin your bearings. Best thing would be to stop Autozone and get a bottle of additive and ad it.
Unless it's a newer Dodge with an AAM axle. It may be the same case with the AAM in the GM trucks too. I accidentally found in my owners manual that the LS diffs in them are not supposed to use additive. I put additive in my 05 and it made it quit working like it should.
