Shiftee
Member
- May 30, 2014
Need some help. Can't figure out why my 4.0 runs so cool. I've never heard of a wrangler running cooler than 200 without a problem. I can drive 3 hours to the beach at 80 mph/3k on the tach and still be sitting just over the second tick mark. (I assume around 180) It's been running cool since I got it but I had bigger fish to fry with re-gearing and getting the txf case to stop leaking. Then my idler pulley decided to come off the other day and after replacing it I noticed the fan clutch was out. So I replaced that and like most things with the jeep turning one bolt turns into a full service weekend extravaganza...
I've...
drained and flushed
reverse flushed
flushed with water and compressed air
flushed the heater core with water and compressed air
run zerex's cleaner for two days (drove 250 miles)
drained the block
flushed some more
thermostat is less than 6 mo. old (stant 195)
water pump is less than 6 mo old
I have decent heat, actually is quite warm
Right now I've got the stat housing/water outlet off and I just tested both the old stat and a new 195 deg stant. Both seem to operate right around 195.
My coolant was pretty sick when I drained it. A little disturbing for the fact that it was changed about 6 mo ago with the stat and pump. I reverse flushed until it was clear. Then after the zerex clean it was pretty sick again. Flushed till clear.
I don't have any white smoke coming out the tail and running to operating temp (albeit low) with the rad cap off I have no unusual bubbling/burping.
I have noticed that my evap solenoid is rapidly clicking during warm up. Shouldn't it be off during cold starts? Could I be staying in open loop?
I just picked up new coolant temp and air temp sensors as well as a new stat housing/water outlet.
Wouldn't bother me too much but I seem to be running really rich.
I'm at the point where I just don't wanna throw any more money at it without running it by you guys. I'm gonna install the new sensors and housing and give it a shot, unless one of you wise men have any ideas I should check first.
I've...
drained and flushed
reverse flushed
drained the block
flushed some more
