Something like this?
Legend:
1. Valve Cover
2. Gasket, Valve Cover
3. Gasket, Cylinder Head
4. Gasket Set, Upper
5. Gasket Set, Lower
6. Filter, Engine Oil
7. Pump, Oil
8. Gasket Set, Oil Pan
9. Cap, Oil Filler
10. Plug, Oil Pan
11. Grommet, Valve Cover
12. Piston & Pin (each)
13. Ring Set (for 1 piston)
14. Rod, Connecting
15. Bolt, Connecting Rod
16. Main Bearing, Set
17. Thrust Bearing,Crankshaft
18. Bearing, Connecting Rod
19. Camshaft
20. Bearing Set, Camshaft
21. Plug, Camshaft
22. Plug, Oil Hole
23. Sprocket, Camshaft
24. Valve, Intake, Std.
25. Valve, Exhaust, Std.
26. Seal, Valve Stem
27. Lock, Valve retainer
28. Rocker Arm
29. Pivot, Rocker Arm
30. Bridge, Rocker Arm Pivot
31. Pivot Kit
32. Bolt, Rocker Arm Pivot
33. Spring, Valve
34. Tappet (Lifter)
35. Push Rod
36. Timing Cover
37. Gasket & Seal Kit, Timing
38. Seal, Crankshaft Front
39. Snubber, Timing Chain
40. Tensioner, Timing Chain
41. Chain, Timing
42. Sprocket, Camshaft
43. Sprocket, Crankshaft
44. Damper, Vibration
45. Slinger, Oil
46. Bearing, Crankshaft Pilot
47. Seal, Crankshaft Rear
48. Ring Gear, Flywheel
49. Flywheel Assembly
50. Manifold Kit, Exhaust
51. Gasket, Manifold
52. Mount, Front
53. Mount, Rear (transmission)
54. Insulator, Support Bracket
55. Insulator
56. Stud, Insulator
57. Mount Kit
