low fan speed on heat
k5ranger
lexington
the fan blows strong and warm thru defrost but blows weak when switched to vent or floor. floor blows cold, vents blow semi-warm, defrost blows nice and warm....what gives? 90 xj
I had a BMW doing this same thing. Turned out to be the radiator. How the hell does a radiator stop working? Had coolant in it, car had 40k on it. Not clogged externally...Damn Germans!
check this out....if the jeep is off for a few minutes all controls work fine and blow strong until you switch to defrost. once switched to defrost the air only blows thru defrost ducts. when I switch to vent or heat settings i do not hear any flaps open.
