bbbcb04
- Dec 12, 2009
- thomasville
Had my jeep for about a year now i started with a factory jeep on 31s. I first did the 3inch springs then a springover. The 4 banger wasnt pulling nothing but air so i replace it with a 350/350/205 with twinsticks from a 79 blazer also grabbed the axles from the same truck and rebuilt them with lockers and 456 gears and high steer .All this wasnt that hard because i had some freinds that had already done the same thing to theres so pretty much just copied what they had done . Then i added the 38.5 /17s and it wouldnt even go in the garage so now i am going to lower and stretch the rear .
Replacing springs with factory yj springs
heres were we started
started cutting off the rear spring hangers
moved them back 2 1/2 inches
then moved to the rear
welded the doner tube in
gonna used the front hole in the ruff perches
had to modify the gas tank and skid .saw this on jeep forum
got the rear mock with wheels on
heating the tank up with ready heater .
that gave me hard time took about three hours of work
After i got the rear done i put the tires back on and ran into this.
with the old springs it looked good
so i order so 1 inch spacers and longer studs $$$$ .
moved the tierod to the back hole and the drag link to the front
i built the fenders last summer
along with the genright rear strected corners and flares
now imganna have to highline the front fender
im gonna finish my rockslider first so i can match them to the fenders which not looking forward to .
need a new welder mine does ok bot need one with little more a$$.
Thats it for now gotta start getting parts together for hood and fenders,hoodpins and some more metal, paint .
lmk what you guys think.
