LQ4 gurus, starting problems...
rockcity
everyday is a chance to get better
Greenville, NC
Buggy doesn't seem to want to start. Started just fine last week. This week, no go...
It'll turn over and fire just a second then will quit just as quickly. Doesn't even get above 400rpm when it half-ass fires and cuts out just as quickly, like in 1 second.
Thoughts? I don't have a scanner, so I'm SOL there.
Check engine light hasn't come one, but I'm not completely sure its working.
Any initial ideas?
Rob
tps?
but you are gonna need codes/or active look in....
no idea.
Its never had a problem before. Started up just fine last week. This week, nothing. Its sat in the same spot since last week. Nothings changed, so I'm clueless.
Anyone close to Greenville with a scanner?
Getting spark?
It'll start without a cam position sensor, but IIRC it will take a while. crank position sensor fail will lead to a no-start condition.
Do you smell fuel out the tailpipe (or see it if you crank with a spark plug out?)
I have a borrowed scan tool. I'm going to check it out tonight. If I find nothing, only guess would be a fuel pump and/or filter
