ltoy
- Jul 28, 2010
- New Hampshire
I have been wondering what people have experienced or seen as failures when using the LS series of engines in buggies.
The old school Small Block or Big block With TBI or Propane is hard to beat. Only 12 volts needed to run on Pane and TBI is just about bullet proof.
I know the 5.3 and 6.0 are good engines the power curve of a Big block with the package of a small block. My only hesitation is all the electronics on them .They are all coil on plug The ecm controls everyting. Cam Crank Knock 2 O2 sensors TPS ect.. Not to mention if you get a Drive by Wire one. Has anyone been stranded or had to go for parts due to an electronic failure on these motors? Is anyone taking special precautions as far as Water proofing? Anyone pulling the intake and sealing up the Knock sensors?
I like the Simple stupid aspect of the Old school motors. but I like the power torque weight of the new stuff. Now a days you can get reliable 450 Hp from a cheap build of a BBC and for the same coin you can get a takeout 5.3 or 6.0 but is the complication of the 5.3 or 6.0 worth the extra work? I am evaluating my Motor Options and I am kind on the fence on what direction to take.
