I have successfully converted a few rigs to SD (really not that hard to do).
The IAT sensor and pigtail are about $25 and will fit right in the evap solenoid hole in the manifold. And I like getting rid of the MAF and the plumbing nightmare it comes with (if you want it done right).
It is nice to have one less expensive part that can fail and make your engine run like shit IMO.
I do agree that the theory says it helps at part throttle etc, but I have yet to experience a loss in performance or driver feel after deleting a MAF/swapping to SD.
I didn't know about safeties built in the stock ECU. Right now low oil pressure is my main concern and I don't think the factory ECU monitors it. I know you can wire it in through the EGR or AC sensor ports then make custom PIDs, but that probably doesn't let you set up a custom safety table, nor is something that 99% of the people wiring their buggies are interested in / would feel comfortable doing.
