ckruzer
Infidel
- Jul 2, 2015
- asheville nc
Reposting from build thread. Maybe someone will have some input before i set fire to the build.
Post:
No start again...
Changed the 12v switched wire for the pooter to the chassis harness wire for the old coil + wire. This is a 12v wire in the On and Start position. So that issue is resolved. Made the 'grounds' more grounded as mentioned below. Cant get better than that. And hardwired the fuel pump power and the fuel sender wires in. And as mentioned below got the pump/sender ground direct to batt negative. So should not have any ground issues here
Not sure that I am getting fuel pressure. I know the fuel sender is working. Not sure the ecu fuel pump power wire is powering the pump. Dont hear it turn on and not sure if should hear it or not. I can only get the fuel gauge to move when i have the ground to the pump/sender assembly ground directly to the battery. Grounding to the frame does not work. Odd? I also had someone crank for me while i used a scribe to push the pin on the fuel rail crossover line to see if there is a air lock issue. No fuel squirted out if it was supposed to.
This engine is a return type engine. And i have the return on the rail capped and i am using a wix filter for return closer to the tank. The filter is hooked up right with 5/16 line going to return and 3/8 going to feed.
I dont have the MAF or the O2 sensors plugged up. But it should still start and just throw codes?
The engine harness, battery negative, body, and chassis harness grounds are all connected together and ground to the block. Should NOT be having a ground issue. So safe to eliminate this? Dunno.
Post:
No start again...
