ckruzer
Infidel
- Jul 2, 2015
- asheville nc
Ok. Looking for some expert input. Now that have ran the engine for prob 300 miles or so, pulled all the computer stuff with a reader. Looking for some help understanding, dissecting and making necessary changes (if any)!
YJ. 5.3 truck engine. ax15. return fuel engine, but blocked; tables adjusted. emissions deleted.
Readings took with engine off, key on.
THANKS FOR THE HELP!!!!
DTCs
172, too Rich Bank 1
175, too Rich Bank 2
550, MIL (not hooked up yet)
FUEL
Fuel System 1 Status - OL
Fuel System 2 Status - OL
Short Term Fuel Trim B1 - 0.0%
Long Term Fuel Trim B1 - (-)1.6%
Short Term Fuel Trim B2 - 0.0%
Long Term Fuel Trim B2 - (-)1.6%
Short Term Fuel Trim B1 to S1 - 0.0%
Short Term Fuel Trim B1 to S2 - 99.2%
Short Term Fuel Trim B2 to S1 - 0.0%
Short Term Fuel Trim B2 to S2 - 99.2%
OXYGEN
(only have pre cat o2 sensors. computer guy supposed to have deleted or turned off downstream)
Oxygen Sensor Output Voltage B1 to S1 - 0.000v
Oxygen Sensor Output Voltage B1 to S2 - 0.440v(+/- 0.005) < engine is off...?
Oxygen Sensor Output Voltage B2 to S1 - 0.025v(+/- 0.005) < engine is off...?
Oxygen Sensor Output Voltage B2 to S2 - 0.0440(+/- 0.005) < engine is off...?
OTHER
Intake Manifold Absolute Pressure - 94.0 kPa
Ignition Timing Advance on #1 Cylinder - 0 Degrees
Calculated LOAD Value - 0.0%
DTCs
FUEL
OXYGEN
OTHER
