336wheeler Well-Known Member Joined Sep 9, 2006 Location Boone Jun 29, 2007 #1 Whats the cons of magnesium inserts for H1s?
sha_ba_do_bang Joined the Band Banned Joined Aug 11, 2005 Location Wilmington Jun 29, 2007 #2 they will put on a good show if your rig burns to the ground i can't decide if that a pro or a con
rockmafia Well-Known Member Joined Apr 2, 2006 Location sedalia nc Jun 29, 2007 #3 If you don't cut them down, plan on them cutting down your tires.
Bishop Well-Known Member Joined Jul 22, 2006 Location north of Greensboro Jun 29, 2007 #4 How much should you cut off of them?
336wheeler Well-Known Member Joined Sep 9, 2006 Location Boone Jun 29, 2007 #5 Going with the PVCs. Thanks.
Chuckman Well-Known Member Joined Oct 9, 2005 Location Huntersville Jun 29, 2007 #6 cut them flush with the spacer section with a sazall and a good mask!
336wheeler Well-Known Member Joined Sep 9, 2006 Location Boone Jul 3, 2007 #8 Because if you air down, that ridge on the insert will cut your tires will cut your tires. You only need the lower clamping section of it.
