Heres the deal I bought a 1998 jeep cherokee with 198,xxx miles about two monthes ago I have put about 700 miles on it since I bought it. I had the engine, transmission, and transfer case replaced because it was a non runner when I bought it. Thats not where the problem is the problem is this: When I am on the highway between 62-70 miles per hour the entire jeep starts to vibrate it originates from the front end (possibly axle/ or wheels) and then the closer you get to 70 mph and above the worse it gets. I know the jeep has high miles I think it may be originating from worn out control arm bushings on the front axle or the such allowing the axle to move around and shake while driving this only happens at speeds of 62 mph and above it gets worse as you approach 70mph and above though. ANY IDES ITS ACTUALLY SO BAD IT GIVES ME A HEADACHE!!!
please post replys and send pms if you know anything about this. espically if you've experienced this before.
