I picked up a Cole-Hersee master disconnect switch recently. Its P/N 2484-16, http://www.colehersee.com/catalog_top/index.htm and is rated for 175A continuous / 800A intermittent.
I was originally planning to mount it under the hood for the convenience of flipping a switch to disconnect my battery when not using the jeep instead of disconnecting the battery leads. I did a little web surfing and found this switch is used for “emergency disconnect”….so this got me thinking.
Would it be worthwhile to mount in the cab within reach? I have 2 12V ignition powered circuits (one for the fuel injection and one for everything else), plus the starter lead. Under normal circumstances, the ignition key can de-energize. In a rollover scenario,….. potential shorted wires, gas leaks….it would pay to have this switch conveniently located. I can find room to mount in the cab.
My question, for those who often find themselves rubber side up, is this worthwhile or is it overkill. I have a lot of $ and time invested in my rig and the last thing I want is a fire. What do you use to kill your power in a rollover. BTW I have a separate winch battery.
