Is the max angle for a cv joint about 30 degrees? How do these super-flex buggies deal with driveshaft angles? Most of them run limit straps, which I will do, but I'm trying to get the most out of my setup. In my current design configuration, I'm using a flipped front axle as a rear. At full bump, there's about a 6 in height difference between the xcase output and axle centerline. Using 16" air shocks, that's potentially 22" height difference on a 30" long driveshaft (flange to flange) which is 47 degrees. Dropping the xcase below the frame rails 2" and using 14" shocks gets me to 34 degrees. I really don't want to extend the wheelbase any further either. I could decrease my ride height a couple inches, but I would not be too happy with the breakover angle. I should also mention that there is a 8 degree angle between the flanges in the lateral direction (looking from the top).
What's the best I can expect from a drive shaft that won't cost one million bucks?
