Nissan11
- Nov 29, 2005
- Marston, NC
My gf has a 01 mazda 626. Last night she pulled into the driveway and the car was idling rough and the engine was making a noise like something was banging around under the hood. I took the car up the road and it ran poorly and when I reved the motor it had a very odd tone, kind of like an indy car. I lifted the hood and did not see any issues. When the car is running, the noise sounded like it was coming from the valves or timing belt. Today I took a few minutes and unplugged some wiring and removed the coolant reserve bottle. I was able to pull back the top front corner of the timing belt cover and I saw pieces of plastic resting against the sprocket. I was able to pull one piece out with pliars and it is about 2"x2" and slightly curved. It looks like a piece of the timing belt cover. Also, the drive belt (serp. belt?) is cutting into the timing belt cover near the fire wall. Its as if something inside the cover is pushng out on it and forcing it into the belt.
This looks a lot different than the timing belt setup on my frontier because the timing belt is on the side of the motor in the mazda. What do I need to remove to get the timing belt cover off? It appears as though it is in at least 3 pieces? Do I have to remove the passenger side motor mount? Do I need to remove the AC lines? Im guessing that all of the pulleys will need to be removed? Is there more than one tensioner for the drive belt? Any help is greatly appreciated! I do not know much about mazdas.
She said she noticed this problem when she started her car after work. Also, the check engine light has been on for a few months but I never found anything wrong with the car when I checked it and I assumed it was just a bad sensor somewhere.
