Rick Deckard
New Member
- Jul 31, 2015
- Hillsborough
Greetings!
This is my first post. A kind gentleman on another forum recommended that I post my request here. I hope he was right!
I usually make my own repairs, but I'm in a bit of a bind, so I would like to find a local YJ guru to install a HEI distributor on my 87 YJ.
The YJ is stalling every 5-15 minutes, and I've ruled out fuel problems. Rather than throw money at the ignition control module and coil, I'm swapping them out with the HEI. In the bargain, I'll also be able to get rid of the spark amplifier that the previous owner put in there fourteen years ago.
I'm located in Hillsborough, NC. I know some mechanics, but none of them specialize in Jeeps. I realize that the HEI install is pretty simple, but I would like to find someone who is familiar with the HEI swap because there is a lot of wiring to remove, some wiring to relocate, and some other wiring to replace (because the stock harness gauge is likely too lightweight).
If I had more time, I'd muddle through the swap on my own, but I'm short on time and have a lot of other responsibilities at the moment, so I'm asking for help finding the right guy or shop for the job.
I've already heard good things about J-Medic, but they are too far for me to travel. If possible, I'd like to find someone in Hillsborough, Efland, or Mebane. I'd even find a way to get to Durham if necessary.
So I put the question to you, kind readers: Can you refer me to a good local YJ mechanic to help me with my HEI Install?
__________________
1987 YJ, 2.5" leaf lift, 3" body lift, slip yoke, Tatton rear drive shaft, steel brake lines, 33x12.50R15 Cooper Discoverer AT/3 on Sidebiter IIs.
__________________
